Salta al contenuto principale
A top-loading washing machine by Fisher&Paykel.
Displays Out of Balance and then stops
Fisher and Paykel Top Loader Model: WA8560E1.
The machine stops and displays "Out of Balance" even if only a few clothes in it mostly at when Time to Go display is 27 and 10. Tried many times to reshuffle clothes in it and press "Start/Pause" button. It starts working and stops again with the same message. Kindly help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @anill31814
Here's the service manual that may help.
Go to p.14 of the manual to see all the possible causes for an out of balance error - code 03 in diagnostic test.
If a part is faulty and needs to be replaced search online for F&P WA8560E1(insert model code e.g. 92233-A or 92245-A etc) parts to find a parts list that shows the F&P part number for the part.
Then search online for the part number to find suppliers that suit you best.
Here's just one example. This is for a model/code WA8560E1 92245-A.
Be aware that even though the model number is the same if the parts list is for a machine with a different model code, then the part may not be applicable to your model. So ensure that you're looking at the correct parts list or confirm with the supplier that it is OK for your machine. The model code is found next to the model number on the product information label on the back of the machine .
Punteggio 2
1 Commento:
Thank you so much @jayeff for your support. Regards
da
Aggiungi la tua risposta
Anil L sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 32
Tutti i Tempi: 362
