Salta al contenuto principale
The Sony Cyber-shot DSC-HX400V is a hyperzoom bridge digital camera that features a 20.4-megapixel Exmor CMOS sensor and 100-times digital zoom.
Is there an internal battery?
My camera will no longer turn on or display a menu with or without a charged battery and plugged into usb charging. Is there an internal battery that might need to be replaced and how would I go about doing that?
Questa è una buona domanda?
Punteggio 0
1 Commento
I have this problem too. Were you able to change the battery and did it fix the issue?
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
@dwjohnson30243 yes, it does. Sony part number for that is 1-756-710-12 and it looks like this
Immagine
It is soldered to the mainboard
Immagine
Use something like this teardown Sony Cyber-shot DSC-HX400V Teardown to get to it :-)
Punteggio 1
2 Commenti:
Soldered? So Sony doesn't consider this user replaceable?
da
@dwjohnson30243 Nope! OEM's do not consider anything user replaceable if they can make a buck on it.
da
Ho risolto, grazie per i vostri consigli. Antonio
Punteggio 0
Aggiungi la tua risposta
DWJohnson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 25
Ultimi 30 giorni: 59
Tutti i Tempi: 748
