My purifer unable to fill water in its tank?...why?
Questa è una buona domanda?
Likely calcium build up in the lines.
If you can, push a straightened metal coat hanger thru the fittings and pipes or use a calcium cleaner within a bucket to soak the fittings and pipes. Make sure to fully rinse off the cleaner from the parts and let the water run a bit before using.
Ultime 24 Ore: 4
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 50
@sehajarora80537 let us know if you have a make and a model for this. You also want to post some pictures of your setup. Let's see what you got going on there. Aggiungere immagini ad una domanda
Mine uses a prefilter that require frequent changing. I clean mine every 3 months of use with food grade citric acid.
da oldturkey03
