Salta al contenuto principale
Stampante multifunzione a serbatoio d'inchiostro Wi-Fi Epson EcoTank L3150
Scaner dosnt work , it's stick.
When i pick to scan , they scaner makes a sound like it's being stuck ando don't make the copy.
Questa è una buona domanda?
Punteggio 1
1 Commento
See for any paper jams etc, Head cleaning, ink charging, or ink drying is in progress. Check to see if the Pause light is flashing.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
That is common problem for this type (l3150, 3110, 3210) this problem cause by:
  1. Improper scanner attached to its pin.
  2. Hard stuff/heavy stuff felt down on to the scanner.
  3. Dust accumulate on the scanner tract.
Solution:
  1. Check ribbon scanner cable, whether it is torn uuo or not.
  2. Dissemble the scanner and clean the track, while repositioning the scanner correctly (don't miss even half millimetre).
Hope this will answer your questions.
Punteggio 1
Aggiungi la tua risposta
Nahum Alejandro sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 741
