Salta al contenuto principale
The Wii Nunchuk was an accessory created by Nintendo for the Wii system in 2006.
3 Domande Visualizza tutte
Loose Nunchuk stick, how and what to replace it with?
My Nunchuk's stick is loose and started drifting. At rest, it has way more give than my non-drifting Nunchuk's, which indicates to me that the internal stick has worn down. Is it possible to replace the internal stick without replacing the entire stickbox, and if so, where would I get a replacement?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi!
Did you already opened it? Is it the plastic thats is loose? Or the actual analog stick it self? Replacing the analog stick requires soldering but this will fix the drift.
Punteggio 1
Aggiungi la tua risposta
Cych sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 192
