Salta al contenuto principale
Charging port is loose
I am connected the charger to laptop.Battery , adapter,all is ok. But charging is not done , charging port is normal loose.is it time to change charging port
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @anaspirant
If the charging port (aka DC jack - supplier¹ examples only) is only loose you can resolder it on to the systemboard.
If the charging jack is faulty e.g. fractured inner +ve connector perhaps, then it will have to be replaced as it cannot be repaired.
In either case to do the job properly the systemboard will have to be removed from the laptop so the repair can be done.
Here's the maintenance and service guide for the laptop.
Go to p.71 to view the procedure to remove the systemboard from the laptop.
¹ Search online for Elitebook 755 G3 DC-In jack to find suppliers that suit you best.
Punteggio 1
Aggiungi la tua risposta
An ASPIRANT sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 78
