Salta al contenuto principale
Headphone insertion detection doesn't work
I have a pair of verifiably working earphones. I have cleaned the iPod Nano 5th gen's headphone jack with a small ball of cotton dabbed with 99.7% isopropyl alcohol. When I plug in the 3.5mm jack and leave the iPod and earphones on a stable surface, it can play audio through the earphones for hours without issue.
When I attempt to move around (i.e. with the iPod in my hand), it frequently pauses music, as if the earphones are no longer connected and it pauses automatically. Then, when I press the play button (while keeping the earphones plugged in as it has been), one of the following scenarios happens. I don't know what triggers which, and it appears to be random:
  1. It plays for a flash of a second before pausing again as if the earphones are immediately unplugged after pressing play;
  2. It plays out of the internal speakers and no sound is heard through the earphones, as if the earphones aren't at all connected;
  3. It plays extremely loud and distorted audio through my earphone and the internal speaker at the same time. This volume exceeds volume limiter set in the settings menu. When I decrease the volume controls, both earphone and speaker volume decreases.
  4. It plays extremely loud and distorted audio, but only through the earphones and not through the internal speaker. The volume control now works backwards, with the empty volume bar being at the loudest and the filled volume bar being inaudible.
I'd appreciate any idea to what could have been wrong and what I can do to fix this. I was not able to source a combined ribbon-jack part as of 2024, so I want to look at any other idea that doesn't involve simply replacing the problematic part.
I particularly suspect a fault in the headphone detection circuitry. Could one of those small SMD resistors on the jack fpc itself being burnt or shorted?
I have read the long post from 2010 for solutions but none worked. I doubt there's been significant water damage, since it had been sitting in my collection drawer for pretty much all its sleeping life and I have never exposed it close to water while actively using it.
Additionally, I have tried to connect it to my laptop's line in port with an AUX cable in an hope to capture a radio program. It worked but the audio frequently clipped only for this iPod. I could use my nano 6th gen in the same aux-PC mic config with no clipping for FM radio.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hmm. It sounds like the port for the headphone plug has gone funny. What might have happened is the prongs that fasten to their section of the jack have become loose, and are not making proper contact. If you move the ipod, it can cause the just touching prongs to lose contact. They can either fully lose contact, causing the ipod to think the cable has been removed, or it has a tiny gap, causing sparks to leap across, obviously ruining your music. Try replacing the headphone jack and let us know how it goes.
Punteggio 1
1 Commento:
Thanks for the proposed solution. While I would love to take the iPod apart, I have yet found a way to do so without cosmetic damage (in the prying up the back camera&mic cover step), and the battery have swelled slightly since its replacement in 2022, which further increases the risk of me breaking more components in the attempted teardown. If I made up my mind to do surgery on it I'll update how it went.
da
Aggiungi la tua risposta
SZCthebandit ‖ sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 26
Tutti i Tempi: 393
