Salta al contenuto principale
High pitch noise when standby or off
So I've had to unplug this monitor after each use since i sleep in the same room. But It doesn't make any noise when it's on.
It's inconvenient to unplug and plug every time. Is there anything i can do?
The noise is very loud close up and definitely noticeable from anywhere in my room(it's a big room).
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@parsivan sounds like your monitor has issues with either capacitor or coil whine. Time to remove the back cover and to listen to where the whine comes from. Sometimes some strategically placed hot glue or replacing the component will work. Let us know what you find out when you try to isolate the whining part. Post some pictures of it with your Question so we can provide you with some further ideas.Aggiungere immagini ad una domanda
Punteggio 0
Aggiungi la tua risposta
Parsa Mahmoodi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 41
Tutti i Tempi: 363
