Salta al contenuto principale
Repair guides and information for the Ridgid MultiTool. The Ridgid MultiTool head is an accessory add-on that can perform multiple tasks efficiently and conveniently on furniture that needs repairing or modifying. Model number: R8223406
Is it possible to replace the part that holds the blade?
Is it possible to replace the part on my multi-tool that holds the blade on the tool? For whatever reason, the four tips that hold the blade on the tool have broken off and now the tool is not usable. Thank you for your advise on how I can get my tool repaired.
Questa è una buona domanda?
Punteggio 0
1 Commento:
@kendesarmo what exact model is your Ridgid tool?
da
Aggiungi un commento
2 Risposte
Yes, it is typically possible to replace the part that holds the blade on various tools and equipment such as knives, saws, razors, and other cutting implements. The specific process and feasibility depend on the design of the tool or equipment in question.
Punteggio 0
@kendesarmo it will help if you post some pictures of the part you are looking for. Going by your description it sounds like you are referring to the assembly output shaft spline shaft assembly, part number 303626002. Ridgid PB R8223404
Aggiungere immagini ad una domanda
Punteggio 0
Aggiungi la tua risposta
Ken DesArmo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 50
Tutti i Tempi: 778
