Nintendo 2DS Touch Screen not working
Hello, my Nintendo 2DS Touchscreen is not working how do I fix it and what do I need (the bottom and top ONLY register touch)
Questa è una buona domanda?
You will likely need to buy a replacement screen and follow this procedure. The screen should come with the touch digitizer which seems to be the problematic component in your device.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 128
2 Commenti
@maximusgabriel, can you clarify the problem you're seeing? I can't quite make out what it is you're trying to describe. You mention a touch screen issue, implying it's not the LCD but rather the digitizer that's the problem, but then you say the bottom and top ONLY (?) register touch. I don't understand what you mean by that, so if you could elaborate we'll be in a much better position to help you figure out what's wrong.
da Jerry Wheeler
@dadibrokeit
The bottom and the top of the Bottom screen only register touch
da Maximus Gabriel
