Hi @danb907
Here's the service manual for the model series that may help
Go to p.68 to see how to test the ice maker function.
If you decide to replace the ice maker, what is the full model number of the refrigerator as there appears to be different ice makers used in variants of the refrigerator model number that you posted?
Hopefully the following list may help to find the correct one for your model. Perhaps check if there's a part number on the ice maker itself to verify before ordering from a supplier. Search online for the part number only, relevant to your particular model, to find suppliers that suit you best.
According to this supplier here are the manufacturer's ice maker assembly part numbers, for the various model variants.
LFX25973D - Ice maker assembly part #AEQ73110203 Note: The Secondary (smaller) wire connector has 3 wires in it. If original ice maker has 6 wire connector see part number AEQ73110205.
LFX25973D (00) - Ice maker assembly part #AEQ72909603
LFX25973D (ASBCNA0) - Ice maker assembly part #AEQ72909604
LFX25973D (ASBCNA1) - Ice maker assembly part #AEQ72909604
According to one supplier here are the manufacturer's ice maker assembly part numbers, for the various model variants.
LFX25973D/00 - Ice maker assembly part #AEQ72909602 (replaces AEQ72909601) OR Ice maker assembly part #AEQ73110203 (replaces AEQ73110206, AEQ73110209)
LFX25973D/01 - Ice maker assembly part #AEQ72909604
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
Hey there! We replaced the ice maker unit and it is STILL happening to us. Did you find a solution?
da R2b2squared
