In my oppo phone not run updated youtube
This phone isn't compatible with this app written when I open youtube app
Questa è una buona domanda?
You should make use of the browser version of youtube. It allows for a slightly lower level alternative.
i have same problem, then i realize it's cause by full memory and storage.
apps need storage to save it, but need much memory to run.
Hi @ayushmanraj,
Have you tried updating the phone's system software in the phone, you didn't say?
Go to Settings → Software update. Ensure that the phone is online when trying this.
If the phone's software is the latest version, then unfortunately you may have to revert back to the previous YouTube app that did work.
okay the reason behind the incompatibility is an outdated Android version. The Oppo A37 runs on Android 5.1 which is quite old. with that the newer versions of YouTube app may no longer support this version. possible solutions to the problem try this;
Your phone isn't compatible for this app. You also download a Vidmate app to run as youtube. This app is same working as youtube
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 105
Tutti i Tempi: 2,523
7 Commenti
Problems Update
da Baba Ramdev
YouTube not update in oppo a37f
da Muhammad affan abbas
YouTube nhi chalra
da Oppo a37fw
how to fix coloros recovery
da josh
Mere phone m youTube download nahi ho rha hai
da Karan Mahor
Mostra 2 altri commenti
