Salta al contenuto principale
Modello versione metà 2009 A1278 - EMC2326 / processore Core 2 Duo 2,26 o 2,53 GHz
White screen of death problem
Hello, I have a MacBook Pro 1278 2009. When you turn on the device, a white screen appears and nothing else. I've tried all the ideas. Command + R and Command + Alt + R. But all that appears is a folder with a question mark inside. I changed the hard disk cable as well, to no avail. I hope you can help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@rayq2009 This "But all that appears is a folder with a question mark inside" means that your MacBook Pro does not find an OS. It's either a bad disk or the OS is not on it or corrupt. Check this post for resolution of this issue MacBook Folder With Question Mark
Punteggio 0
Aggiungi la tua risposta
rayq2009 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 131
