Salta al contenuto principale
It stops at the HP logo after turning it on.
I am Japanese and I am using Deepl Translate, so please understand that my English may not be correct. When I came home from school today, I opened my computer and pressed the power button, but I could not get out of the first screen with the HP logo on a black background. I was able to use it normally until last night, but suddenly I can't use it anymore. I was playing OSU!, listening to music on YouTube, talking to friends on Discord, etc. on my computer. I have not visited any suspicious sites. I installed about 20 songs of OSU at once and continued to use it even though the back of the PC was overheating. I guess the heat broke the parts inside the computer? I will reply if there is anything I don't understand.
Questa è una buona domanda?
Punteggio 1
4 Commenti
Hi @azppyxauzlrowev
What is the full model number of the laptop as shown on the product information label on the bottom of the laptop?
Is the Caps Lock light blinking on the keyboard when the HP logo is on the screen?
If it is, here's a link that may help. Click on "Identify the Notebook light or beep code" link on the page.
Can you get into the BIOS menus OK - turn on the laptop and repeatedly press the esc key until the Startup Menu opens. Press f10 to enter BIOS Setup Utility.
da
@jayeff The Caps lock button doesn't flash when I press it, I can get into the BIOS menu but I don't know what to do from there.
da
@azppyxauzlrowev Do you have a friend's laptop you would be able to borrow if needed?
da
@andrewsawesome I have another laptop for work that doesn't have a blocker on it.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@azppyxauzlrowev
I meant is the Caps lock light flashing when the laptop stalls with the HP logo on the screen?
You don't have to touch anything.
If the laptop isn't passing POST (power on self test) then the Caps lock light will hopefully flash a code indicating what's wrong.
If it is not flashing you may be able to check the hardware by using the HP PC Hardware Diagnostics UEFI test. See if you can test from either the Hard drive or the BIOS options
Here's the manual for your model. (HP Pavilion x360 m Convertible 14m-dy0013dx)
Go to p.79 and follow the procedure and see if the diagnostic tests are located in either the hard drive or the BIOS so you can test the laptop hardware e.g. ram etc.
If not you may have to download them onto a USB drive as stated and then try it.
Punteggio 1
2 Commenti:
@jayeff Sorry, I'm not very familiar with computers so I don't know where the complete model number comes from, so I'll just write the number on the back.
HP Pavilion x360 m Convertible Model 14m -dy1033 Warranty 1y1y0y RMN:TPN-W146 INPUT:19.5V---3.33A
ProdID 4P8P1UA#ABA SN# 8CG1382ZXL Containa Intel Radio Model AX201NGW
da
@azppyxauzlrowev
I've updated my last comment with the manual for your exact model.
da
Aggiungi la tua risposta
高路亜嵐 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 115
