Salta al contenuto principale
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Part of screen is Grainy
I've tried reseting and it scrolling through the menus. Am I missing something or is it just broken?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Almost certainly a problem with the connection between the flex cable that goes to the motherboard and the etched electronic circuits on the glass (on televisions it's referred to as a TAB error). Unfortunately not repairable; you'll need to replace the screen to fix that.
Punteggio 2
1 Commento:
I've never seen this issue before so I'm inclined to believe you're right. However, I think it's still worth re-seating the ribbon cable as a simple troubleshooting step.
TI-84 Plus CE Teardown
da
Aggiungi la tua risposta
Javan Watson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 31
Tutti i Tempi: 171
