Salta al contenuto principale
Device and repair guides for the Xiaomi Redmi Note 7 Pro smartphone.
After call end screen not show any thing
I got a call on my phone, I picked it up and put it to my ear. After that the phone screen turns off. But when I go to cut the call, the screen does not turn on. I can't cut the phone. I have to turn off the phone completely.so what is my phone issu
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @amolpatil7644
There seems to be a problem with the proximity sensor in the phone.
There are two things that you can try.
a). Calibrate the proximity sensor and check if that fixes the problem.
b). Disable the proximity sensor. To disable the sensor go to Settings → System Apps → Call Settings → Incoming call settings and disable Proximity sensor and check if this works. Note: Be aware that now the screen will stay on during a call and not turn off.
Punteggio 2
Aggiungi la tua risposta
Amol patil sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 189
