Salta al contenuto principale
L'Aspire 3 A315 è un computer portatile riparabile di Acer.
Why my laptop not turning on?
Why my laptop's not turning on and the charging light is not turning on?
Questa è una buona domanda?
Punteggio 10
3 Commenti
naahh no turning on but charging light is on
da
I have same problem with my laptop Acer A3 a315 1st its keypad was not working and now it doesn’t power on I’m worried about it i tried to charge but it doesn’t show i mean no indicator blink. Any solution please?
da
@muhammadaf26857 have you tried what was already mentioned in the answers to this question? What have you checked and what have you already tried?
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
Can be a Keyboard issue. The power button is on a keyboard, and if he fail, the laptop don't boot up.
Try this My keyboard is not working
Punteggio 1
@meenakshi16 you forgot to tell us if there are any LEDs that light up or if your laptop give you any sign of live. TRy this first. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery (if you can ) Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer now shows any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the pins are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger.
After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Since iFixit does not yet have a guide for it, use something like this video to work on it. Post Some good pictures of what you see. That way we can see what you see Aggiungere immagini ad una domanda
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Punteggio 0
When I turn on my pc screen not displaying but flash for few seconds
Punteggio 0
Checkout the following video: https://www.youtube.com/watch?v=m60x7pP0...
Punteggio 0
If no lights, no fan, no response then might be possible it's motherboard issue.
Punteggio 0
Aggiungi la tua risposta
Meenakshi 16 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 126
Tutti i Tempi: 4,791
