No power, can be only the cpu?
There is no light, nothing of nothing, and the power supply is always orange, it seems to output the right voltage, I opened the Xbox (I broke the plastic cover :( ) but what I can relate to this problem is the CPU, is there something that can I check? (sorry for the bad English I hope you will understand me)
Update (01/22/24)
Here they are, i checked the first one said by alex and they seem to be fine, all this white "dust" can be related to the problem? For old turkey, i will check better, but after the isopropyl alcohol will arrive and i have cleaned the board, if you have something where can i check voltages and other things it will help me a lot
Questa è una buona domanda?
Have you checked the contacts downstream of the power input?
da Alex
@frankaaaa you've checked your switch, your wiring,? You've measured any voltages on the motherboard? Checked the voltage regulators :-) It might help if you post a couple of good pictures of your motherboard. Let's see if we can point out a few voltage test points so you can narrow it down. Aggiungere immagini ad una domanda
da oldturkey03
Hello, thank you for the tips, when i'll be at home i'll post
da Frank Aaaa
