Salta al contenuto principale
Dell P2418D 23.8" 16:9 IPS Monitor 2560 x 1440,Black
2 Domande Visualizza tutte
Why its give me Black screen with blue edges and vice versa every time
Black screen with blue edges and vice versa every time I turn it on
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @bx44,
Can you view the monitor's OSD menu screens OK?
Have you tried using each signal input port i.e. HDMI & DP?
da
@jayeff It shows the same thing no matter how much I connect it to any device and it also does not show the OSD menu of the monitor
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @bx44
The power board seems to be OK as it turns on and there's backlighting. You could always inspect it for any obvious component damage e.g. blown capacitors or heat stressed components etc.
I think though that there's a mainboard problem.
Here's a teardown guide that shows how to disassemble the monitor that may help.
Try replacing the mainboard (supplier example only) and check if that resolves the problem.
If you decide to do this, verify that the board you order has the same model number or part number as the original. Usually this is found either printed on the board or on a sticker on the board
Punteggio 2
Aggiungi la tua risposta
Bx4_4 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 25
Tutti i Tempi: 137
