Both brewing options pump the same amount of water
Hi. After cleaning/descaling the machine, both brewing size options pump the same (larger) amount of water. Is there a fix for this?
Questa è una buona domanda?
Try resetting to factory settings: Switch it Off, then On again and press and hold the "Lungo"-button for 5 sec. (The right one). The button should flash three times. The machine will heat up as before - and hopefully the issue has disappeared. Here a Video.
Thank you; that was what it needed 🙂
Well done! Small cause, big effect. ;-)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 60
