Salta al contenuto principale
L'Aspire 3 A315 è un computer portatile riparabile di Acer.
20 Domande Visualizza tutte
Display flickering / blinking issue of acer a 315 laptop
I have recently bought Acer
Aspire 3 A315 Notebook With 15.6-Inch Display, Core i5-1135G7 Processor/8GB DDR4 RAM/512GB SSD Storage/Intel Iris XE Graphics/Windows 11 English/Arabic Pure Silver, its display is blinking / flickering. What type of issue is this hardware or software pls guude
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @shahzebjamil
Try connecting an external monitor (TV?) to the laptop's HDMI port and check what the display from the laptop is like on it. Don't forget to press the Display toggle function keys (Fn + F5) to switch the display output from the laptop screen, to the external monitor, to both on together.
If the external monitor display is OK it may be a problem with the video cable, video cable connection at either end,- motherboard or screen, or the laptop screen itself.
Try gently moving the laptop screen slowly back and forth to see if you can make it stop flickering or even if you can make it worse.
Since you have recently purchased it, I suggest that you contact the Acer customer service section in your location (check the user manual for details) and make a claim for a manufacturer's warranty repair, replacement or refund. Do not attempt to open the laptop to see if you can fix it, as this will void the warranty.
Punteggio 1
Aggiungi la tua risposta
Shahzeb Jamil sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 122
