Why do I getF5 when I turn on my washing machine?
When i turn on the washing machine i get F5 error code
Questa è una buona domanda?
The F5 error code on your Whirlpool washing machine can represent one of several different issues, depending on the specific sub-code that follows it. Here are the possible F5 error codes and their meanings:
To provide a more precise answer, it would be helpful to know the specific sub-code (e.g., F5E1, F5E2, or F5E3) that is being displayed on your washing machine. Equally important, as @jayeff mentioned, we could use your full model number. Typically this looks like "110.********" where * is replaced by a series of 8 numbers. This will allow for a more accurate diagnosis and solution.
My best immediate guess, assuming you are using the washer properly and the simple solutions like buildup or excessive force have been ruled out, is that you will need a new lid lock switch. These are fortunately relatively cheap and straightforward to replace.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 14
Hi @carolsimmons,
What is the model number of the washer?
da jayeff
