Salta al contenuto principale
The Dell Inspiron 15-3511 is a budget laptop manufactured by Dell. This variant is powered by 10th and 11th-generation Intel processors.
9 Domande Visualizza tutte
How to fix bios corrupted?
The last time I turned it on it said bios corrupted but after a few days my laptop doesn't turn on there is a light indicator when I press the power button, and then I try some little research on YouTube tutorial. I tried ctrl+esc to go bios but it didn't work, then came to find the bios bin file so I came here or do you have other suggestions for repair
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi @rrr72079
Try a full power refresh and check if that works.
Here's the procedure:
a). Turn off the laptop if on and disconnect the charger from the laptop if connected.
b). Open the laptop and disconnect the battery cable from the motherboard.
Here's the service manual that will help with this. Go to p.20 to view the procedure to remove/replace the battery. You don't have to remove the battery, just disconnect the battery cable from the motherboard as described.
c). Press and hold the laptop's Power button for a full 30 seconds and then release it.
d) Reconnect the battery cable to the motherboard, reassemble the laptop, connect the charger and check if it turns on OK.
If it does there may be a message saying that the date and time are incorrect. This is normal as the BIOS has been reset back to its factory default setting. Once the date and time are corrected the message won't appear the next time the laptop is started. Also any user definable settings in BIOS that have been changed by you to suit whatever system operating requirements you have, will have to be changed back again as well.
Punteggio 1
2 Commenti:
I already did that but nothing happens
da
@rrr72079
Here's a link that describes problems with flashing the BIOS chips that may help.
Here's one supplier but you have to purchase it. I couldn't find any free downloads at all.
You would also need programming equipment so that you can read/write directly to the chips.
da
Well this video might helpful for you: https://www.youtube.com/watch?v=PVba2c-F...
Punteggio 0
Aggiungi la tua risposta
rrr- sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 41
Tutti i Tempi: 562
