Why is it showing 1E and 0E code
After filling water it spins only 5 times and shows error
Questa è una buona domanda?
Here's the fast track troubleshooting guide for the WA50** series washers.
Run the Quick test mode as described and check if the water level sensor is OK. If it is faulty ii will show a 1E error code and perhaps an OE code as well.
Check that the water level sensor hose isn't kinked or blocked etc and that it hasn't become disconnected from the switch or the hose connection to the tub - see 6:10 minutes into the video linked below.
If the switch is faulty, here's a video that shows how to replace it. Search online for DC96-01703H to find suppliers that suit you best.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 209
