Salta al contenuto principale
Rilasciato a febbraio 2016, identificabile dal numero di modello 20F90017US.
Is the screen the same for T460S and T460
Hello the screen of my father’s ThinkPad broke. I removed it and now Ím asking myself if the screen of the non touch T460S is the same as the one on the T460. Some sellers seem to think that but I read about a 50 nits brightness deferents between both laptops
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @erikstermann
Some are the same but it also depends on whether they're an HD or FHD display as well.
Here are links to the Lenovo part numbers and hardware maintenance manuals for the T460s (20F9) and the T460 (20FM and 20FN) models.
Click on Select Commodity > LCD panels, to find the part numbers for all the panels that can be used by the models. This may help you to check if the panel used in the T460s is also one of the ones used in the T460. One way to find out what panel is in use is to disassemble the laptop and look for the part number on the back of the LCD panel.
T460s: 20F9 parts, hardware maintenance manual
T460: 20FM parts, 20FN parts, hardware maintenance manual
If you need to get a replacement panel, search online using the part number only for the panel you want, to find suppliers that suit you best.
Punteggio 0
Aggiungi la tua risposta
Erik Stermann sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 143
