Salta al contenuto principale
A 13-inch "2-in-1" laptop with a 360-degree hinge that allows it to convert to a tablet-like form factor.
13 Domande Visualizza tutte
Hinges on a 13 5378 inspirion
How can I check my hinges cuz not working correctly now
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Questa risposta era destinata originariamente a un'altra domanda.
Hi @carol29331
Here's the service manual taken from this support webpage for the laptop that will help.
Go to p.50 to view the necessary pre-requisite steps and then the procedure to remove/replace the display assembly.
On p.51 it shows the hinges. You need to check whether there's a problem on the lid side of the hinge or the base side of the hinge as sometimes the hinges themselves may be OK but they may have either come loose from one side or perhaps the hinge screw mount may be broken, which would require either a new lid or base assembly
Punteggio 0
Aggiungi la tua risposta
Carol sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 48
