Salta al contenuto principale
A security and intelligent doorbell that live streams 24/7 and notifies you if someone is at your door.
Where to find replacement gasket?
Where can one find the replacement gasket?
The replacement of this piece is mentioned in its own guide as well as in the battery replacement guide. I have not been able to find with basic search terms.
Thank you in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @kb_kb
If you can't find a replacement gasket, you may have to improvise.
Try either a suitably sized elastic rubber band or perhaps run a thin bead of neutral cure silicone sealant around the case in place of the gasket.
If using the sealant and you need to open the case in the future use either vinegar or Isopropyl Alcohol to soften it first and then pry open the case.
Punteggio 1
Aggiungi la tua risposta
KB_KB sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 12
Ultimi 30 giorni: 41
Tutti i Tempi: 380
