How to replace radiator drain petcock valve
drain valve wont turn open and needs to be replaced. How to get old one out and install new valve
Questa è una buona domanda?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 54
Hi @dougs57198,
What is the year and engine of the vehicle?
da jayeff
2003 std 5.7 base coupe with 1/4 turn white plastic valve which a sq driver just spins and valve does not open or come outwards. I have done it before OK a few years ago.
da Doug .S
@dougs57198
Not sure if access is easy but can you use a pair of multigrips and try pulling the drain cock out as you're turning it?
da jayeff
will give it a try, but now getting cold and I'm likely to delay for a while. Thanks for replies.
da Doug .S
