Salta al contenuto principale
Repair guides and support for bikes manufactured by KTM.
3 Domande Visualizza tutte
Why my bike is not starting
When i switched on the bike the metre is working but the when we push self it is only doing tip tip
Questa è una buona domanda?
Punteggio 0
3 Commenti:
@suhail69026 your question is somewhat hard to understand. Try to rephrase it. If English is not your first language, it is okay to post in your language. We just need lots more information. Things like what year, what model, what you have checked, what you have tried to fix things, and more are all really important.
da
maybe "tip tip" is really "click click" because the battery is low and the engine won't crank. Charge the battery and try again or boost the battery. Get help if you don't know how to do that, it can be dangerous.
da
My bike broke down mid ride 2 weeks ago.
It's still in the shop as my warranty had run out 1 month before. The issue had been going on since collection with 1 battery being changed and other electrical issues being reported under service. Basically it has historical issues and they want me to still pay for it.
The bike made no sound with trying to start it back up. Yet all lights and dashboard were lit up. The ktm mechanic apparently didn't know how to fix it. After multiple calls to check on progress, I get a phone call 8 days later to inform me my warranty is out of date. Kinda p!$$€@ now. Feel like the dealership is taking the p!$$ out of me.
da
Aggiungi un commento
1 Risposta
For an engine to run it need four things:
  1. Fuel - is the engine getting fuel? Is the fuel fresh or is it contaminated?
  2. Spark - are the spark plugs firing when the engine is cranked?
  3. Compression - Does each cylinder have compression?
  4. Timing - all the valves have to open and close at the correct time and the spark plug must fire at the correct time.
Check all of these and ask more questions if required.
Punteggio 0
Aggiungi la tua risposta
Suhail sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 14
Tutti i Tempi: 141
