Salta al contenuto principale
La Ford Explorer e la Mercury Mountaineer sono state entrambe sottoposte a un aggiornamento per l'anno modello 2006 su un nuovo telaio, prodotto da Magna International anziché da Tower Automotive.
Head driver's side
I have a 2006 4.6 l v 8. I had a sparkplug break on me and I bought a puller. The puller pulled the plug but left the threaded end in the head. This is on the driver's side
Can I pull the head and reinstall it without having to mess with the cam as it's a single over head cam. As it would make my job a lot easier. Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@miner64 I am confused by that. Each one of your cylinder heads will have a single cam running on top off the head. Just remove your valve cover and you will see that there is a cam. One per side. Something like this
Immagine
from a 4.6L SOHC Explorer
No matter how you look at this, it's going to be a PITA but it's doable.
Punteggio 0
Aggiungi la tua risposta
Ernest sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 21
Tutti i Tempi: 220
