Salta al contenuto principale
Rilasciato a maggio 2018, questa è una versione plus del Samsung Galaxy A6, che aggiorna lo schermo da 5,6" a 6,0" e la fotocamera da 16 megapixel a una fotocamera da 24 megapixel.
The charging jack problem
The charging jack of my phone is damaged and the charging keeps shaking when I plug in the charging cable.The charging jack of my phone is damaged, it keeps shaking when the charging cable is connected, how can it be fixed, please help me.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta più utile
Rohit, unfortunately your charging jack is mounted directly on the motherboard so unlike other Samsung models, there isn't a separate part that can be replaced to fix the charging port.
I'm afraid you're going to have to find someone experienced in microsoldering who can remove and replace that tiny port from your motherboard. I consider myself fairly talented at soldering but I would hesitate to attempt this one on my own; if you're not really good at it I wouldn't recommend trying to fix it yourself.
The closest I can come to offering you help is this guide showing you how to remove the motherboard so you can get to the charging jack, but after that I'm afraid you're on your own.
Manuales / Samsung Galaxy A6+ / Motherboard
Otherwise the only thing you could do would be to replace the entire motherboard, which is basically going to be the same as replacing the whole phone.
Punteggio 3
1 Commento:
Hi @rohitsaxen93718,
Here's the part number for the charge port connector - 3722-003954
Search online using the part number to find suppliers that suit you best
da Condividi
Aggiungi la tua risposta
Rohit Saxena sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 17
Tutti i Tempi: 760
