Salta al contenuto principale
Why is my adapter overheating
Any time I try to charge my pc, my adapter overheats after a few minutes
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @wisdomodame
It could be a faulty adapter, faulty adapter cable or a problem in the laptop.
Try using another known working, compatible adapter and check if it heats up or is OK when connected to the same laptop.
If it works OK then the problem is in the original adapter or adapter cable.
If it also heats up then the problem is on the motherboard in the laptop. The schematics would be needed to find out what's wrong on the motherboard. Unfortunately if the motherboard model number is LA-B171P (as printed on the board itself) I can't find a schematic online, you may have better luck.
Punteggio 0
Aggiungi la tua risposta
Wisdom Odame sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 66
