Salta al contenuto principale
The Airpods Pro 2nd Generation is a revision to the original Airpods Pro. Released on September 7th, they allowed better audio, 2 times more noise cancelling, and volume controls. It also boasts a larger battery, and a speaker on the case to make finding them easier.
18 Domande Visualizza tutte
My left airpod won’t charge
My right AirPod won’t charge
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
Hello, I've experienced this before in other wireless earbuds it can be an easy fix! The first and foremost action will be to clean the case and bottom of the pod with a cotton swab and 90% or higher isopropyl alcohol ensure that both are dry before trying to charge. If that doesn't fix the problem ensure that you have the most up-to-date software and the battery level on your case. Last resort just reset the buds by disconnecting them and reconnect them. If the problem persist it may be something internal in the buds in which case take them to a repair shop or contact Apple themselves. Hopes this helps!
Punteggio 0
Battery problem low battery pick up
Punteggio 0
1 Commento:
What is problem
da
I had the same problem with my charging case. It's not the AirPod but the two contacts on the bottom.
To fix it I gently had to pull the brass contacts out and it would charge again. I dunno how this came about but I noticed when it would load before when I pressed it down and left it would charge again before the fix.
Punteggio 0
Aggiungi la tua risposta
Manpreet Singh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 49
Tutti i Tempi: 968
