Salta al contenuto principale
OnePlus released its first smartwatch in April 2021. The OnePlus Watch comes with Wi-Fi, Bluetooth, 1 GB of RAM, 4 GB of storage, speakers, and GPS.
cold battery will not charge where do you buy battery?
will not charge says cold battery
Update (09/25/23)
where do you buy battery for plus one watch
Questa è una buona domanda?
Punteggio 1
3 Commenti
Could be a bad temperature sensor.
Li-ion batteries shouldn't be charged below 40 F ( ~ 5 C) so there is a sensor to check for this.
If you warm it up, can you make the message go away?
da
Not work my wacth
da
A comedian. Very funny. My wacth (sic)
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
@frankdidente could be a bad battery. The battery has a temperature sensor, and a failed battery control board can give you that error. Start by replacing the battery.
Check this Smontaggio OnePlus Watch and see if this is something you would tackle.
Punteggio 1
I replaced the battery and it worked using battery from:
I just found this on AliExpress:
C$37.99 | new original for OnePlus XE202 Watch battery
https://a.aliexpress.com/_mOAz1z9
The wearable now works!
Punteggio 1
Aggiungi la tua risposta
FRANK DIDENTE sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 265
