Salta al contenuto principale
The Dell Dimension 2400 is a desktop computer released in 2003 with a traditional box "tower" form factor and a black exterior. It is the last machine from the Dimension 2xxx series and is equipped with a Celeron or Pentium 4 processor.
In cpc power supplying is not coming
In cpu power supplying is not working
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@devika14103 checked the power supply by disconencting the power supply from the motherboard. Then place a jumpoer between the green wire and a black ground wire. Since we do not know exactly what power supply plug you have, it will help if you post a picture of it with your Question. We can then show you where to place the jumper. Aggiungere immagini ad una domanda
If it does not work, you know you have a bad power supply. If it does work you need to check the power button as well as the motherboard.
Punteggio 0
Aggiungi la tua risposta
Devika sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 131
