Acura ilx 2016 spark plug replacement
How to change acura ilx 2016 spark plug and which plugs are good
Questa è una buona domanda?
@noor80568 use something like this video as your guide. Replacement plugs would be something like Bosch Double Iridium Spark Plug 96310 or for a more economical option use the Autolite XP Iridium Spark Plug XP5682
While you work on your Acura, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
On the Acura ILX, you need to use iridium plugs; you can find them here. No need for double iridium, but you at least need iridium-coated ones with some of the newer Honda engines; yours is one of them. Try and use the OEM NGK, but the Bosch and Denso plugs will be (nearly) as good as the OEM NGK.
In order to change them you have to remove the beauty cover (usually clipped on in Honda engines; removal method varies from prying or a flathead), then disconnect the ignition coil wires. Once you do that, get a good spark plug socket. We don't have a guide, but it takes a half hour to do this. The main thing to remember is you want them to be snug, not tight.
When I check against the car, the ones you got are a match.
I bought these plugs kindly guide me these plugs would be good for acura ilx 2016 Just found this amazing item on AliExpress. Check it out! C$25.46 30%OFF | 2-8PCS Replace for Candle DENSO DXE22HQRD11S 91578 DILKAR7G11GS 0242140555 VR6NII352U Double Iridium Spark Plug Torch LD7RJII-11
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 234
10 Commenti
I have these plugs kindly tell me these would be good or I need other's new ugs
da Noor
@noor80568 you need to make sure that you have the right plugs and that they are new.
Which plugs do you have?
da oldturkey03
@noor80568 As long as they're quality iridium plugs, they'll work for you.
da Nick
@nick you still have to make sure that you use plugs that are specific to that engine. It still needs to have the right gap, right length right thread, the proper internal resistors and heat range. It is not enough to just be an iridium electrode plug :-)
da oldturkey03
I ordered these plugs these would be ok kindly guide me
da Noor
Mostra altri 5 commenti
