Salta al contenuto principale
L'HP Elitebook Folio 9480m è stato rilasciato il 4 luglio 2014. Il modello 9480m può essere identificato dal numero di modello J5P80UT.
Laptop Show charging but battery % not increase
My Laptop show charging but battery it not increase the battery power Can this is Charging IC Problem?
Questa è una buona domanda?
Punteggio 3
2 Commenti:
pls my laptop elite book folio 9470m anytime i open the laptop, like while raise the laptop it display white if i move it back a little it display normal
what could be wrong with it is it the flex?
da Condividi
Charge cannot fast battery
da Condividi
Aggiungi un commento
1 Risposta
@abdullah9805 yes it can be. The very first thing you want to do is to change your battery. That can also be the reason for slow charging. The Battery control module is commonly what regulates the charging. Download the maintenance and service manual from here to work on your laptop.
This HP Elitebook Folio 9480m Troubleshooting will help with some quick troubleshooting.
While you work on your computer, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Punteggio 0
Aggiungi la tua risposta
Abdullah sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 35
Tutti i Tempi: 591
