Salta al contenuto principale
The MSI GF63 Thin is a gaming laptop featuring a thin bezel display, powerful processors, and dedicated graphics cards. It's designed to be portable and lightweight, making it a good choice for mobile gamers.
13 Domande Visualizza tutte
Why my Nvidia gtx gpu not working?
Nvidia gtx Graphic card not working and nvidia control panel not opening
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi @swetekka,
Check in Device Manager > Display Adapters to check the status of the Nividia GPU.
If there's a red cross, right click on the adapter entry and select enable
If there's a yellow exclamation mark, right click on the entry and select update drivers - you need to be online to do this one.
If no entry in DM, check in BIOS to make sure it isn't disabled there.
Punteggio 1
2 Commenti:
I did that but not working, when I play games every time freezer image or out and come error report.
da
Hey @swetekka
Sorry for the late response but have you fixed the issue?
If you have then please let us know how you fixed it.
If not then have you tried updating the drivers for it?
da
I feel like it could be a cooling issue with this model my GF a a gf76 with rtx3070 and i took it appart and under the cooling the graphichs chip had partly burned making a bubble on it, the gpu works but bugs and crashes
Punteggio 0
Aggiungi la tua risposta
Swet Ekka sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 306
