Salta al contenuto principale
Troubleshooting and Repair for the 32" 1080P LG 32CS560 LCD TV.
Why is screen track still audio ok
Why is screen track stiil audio on
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@mulugetagashaw it seems like something gets lost in translation here. I understand your question to be why the screen is black but you still have audio.
A few things you have to check for on this. First you need to verify that you have no image on all inputs. Try all of those. If it remains dark, unplug everything that is plugged in the back of your TV. unplug the TV and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Aggiungere immagini ad una domanda for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
If I misunderstood your Question, let us know by revising it.
Punteggio 0
Aggiungi la tua risposta
Mulugeta gashaw sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 4
Ultimi 30 giorni: 26
Tutti i Tempi: 203
