Why is my screen showing distorted images/ colors?
Vedi il contenuto dell'immagine:
Questa è una buona domanda?
There are a few reasons why your screen might be showing distorted images or colors. Here are some of the most common reasons:
Here are some things you can try to fix this:
If you have tried all of these things and you are still having problems, you may need to contact a computer repair technician for help.
This is a SNES not a computer. So not sure that if what you put applies to some degree or not here.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 186
I have tried different power supplies, RF cable and R/W/Y composite cables. No difference. Also cleaned cartridges and pins in the console.
da Talonrevenge
@talonrevenge Have the electrolytic capacitors on this console been replaced?
da Andrew S
@andrewsawesome not that I am aware of.
da Talonrevenge
@talonrevenge Have you cleaned the pins on the video connections or the cartridge connections?
da Justin Castle
@erelectronics yes I have cleaned them.
da Talonrevenge
Mostra altri 2 commenti
