Salta al contenuto principale
The Claw is a small scale electronic arcade game with flashing LED lights. This candy and toy grabbing machine designed for home use.
16 Domande Visualizza tutte
Replacement parts in the battery section
My battery contacts got corroded can I replace the springs and positive plates for better connections?
Questa è una buona domanda?
Punteggio 0
1 Commento
@terrydulong let's see what this looks like. Post a couple of pictures with your question. That way we can see what you see. Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes you can, sometimes a bit of sandpaper to remove the rust works too if you're unable to replace the whole spring. Alternatively, metal spacers like thin washers or a small coin placed beside the spring before installing the battery can help compress the spring to bypass the rusty portion.
Punteggio 1
Aggiungi la tua risposta
Terry Dulong sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 73
