Tuscon will not run loud squeal when trying to start / run. 35,000 mil
Tried removing serpentine belt and engine makes the same squealing noise when trying to start. p052 code
Questa è una buona domanda?
Please verify the ODBII code.
Looking at Hyundai codes it is not listed and online there are OBDII P0052 codes, but no P052 codes.
P0052 refers to a heated Oxygen sensor, bank 2 sensor 1 problem.
Only trouble is your engine only has Bank 1 sensor 1 and Bank 1 sensor 2 which would cause P0030 and P0036 codes unless the code is a Hyundai specific OBDII code
Here's an image showing the location of the two sensors in your vehicle, just in case it is a loose or fractured wire connection to the sensor(s).
(click on image)
Here's a link showing the possible causes for a P052A code.
Here's an image showing the location of some of the sensors mentioned for the code.
(click to enlarge)
It’s showing P052A.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 75
Hi @minnesotatuscon,
What year model and engine size and type (gas, diesel) is the vehicle?
da jayeff
2017 Hyundai Tuscon 2.0 engine
da Minnesota Tuscon
