My TV sometimes starting start OK sometimes can see horizontal lines
TV 65" intermittently can start OK and could work for many hours until I shut it down. Next time it could show horizontal lines moving down and it will not respond to any remote buttons, only Power. I have to restart TV several times and again it could work in normal way. I replaced Main Board with RCA board and now have splash screen with RCA logo, but problem stays. Replaced T-Con board - no change. Disconnected IR sensor and connected two wires with switch for ON-OFF control - no change. Power supply board checked and power is good. This is very strange problem for me. The only thing I did not replaced is screen and long board on the bottom of the TV with all the screen wiring. Please help.
Questa è una buona domanda?
2 Commenti
Could you post a photo of the issue? More importantly, when you checked the power supply board was it checked while the TV was functioning normally or while it was this "horizontal lines moving down" issue?
I would recommend repeating your power board test when the TV is working properly, and then power cycling the TV multiple times as necessary to get the TV not working properly and then testing again and seeing if it is still outputting power the same.
It sounds to me like a power issue of some kind that is intermittent, so verifying that the power supply is outputting power, either properly or improperly, during the issue occuring is important to confirm or deny.
da Justin Castle
I just check voltages on power board. They are completely the same in both cases. Connector 2 +12.19, Connector 4 ADJ = 2.28, BK-ON = 2.84, and two pins are =12.18v
da Alex
