Salta al contenuto principale
Why is my laptop not booting up
Hi. I have a HP 820 g4 laptop that's when I turn it on the WiFi and power button LED lights are on but the caps lock blinks 5 times then shutdown the laptop
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @victoromayo
Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Disconnect the main battery from the motherboard.
c). Disconnect and remove the RTC battery from the motherboard.
Here’s the maintenance and service guide for the laptop. Go to p.35 to view the necessary pre-requisite steps and then the procedure to remove the battery and then p.65 to remove the RTC battery. Unfortunately with your model you will have to remove the motherboard to access the RTC battery.
When the RTC battery is removed measure its voltage. If it is <2.6V DC replace it. The part number is 702853-001. Search online using the part number only, to find suppliers of the part.
d.) Reconnect the RTC battery (or its replacement).
e). Reverse the above steps to re-assemble the laptop.
f.) When the laptop is completely re-assembled, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
Punteggio 0
Aggiungi la tua risposta
Victor Omayo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 17
Tutti i Tempi: 349
