Can the battery be replaced/fixed?
Over charge the battery now it last just a day where as before I only need to charge the band once a month
Questa è una buona domanda?
@muhammadnaqib yes it can but it's not easy. The challenge will be to open the device. Check on videos like this to get an idea of what is involved. Depending on your device model, do an online search for the battery ones you have it open and can read the numbers on the battery. If you are stuck or see something that requires more info/help, post some pictures of that with your Question. Aggiungere immagini ad una domanda
While you work on your device, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 76
