Salta al contenuto principale
Parte di una linea di pompe a vuoto manuali realizzate da MityVac, la pompa MV8000 viene fornita come kit di riparazione insieme a tubi, adattatori e serbatoi per liquidi, per operazioni come lo spurgo dei cilindri della frizione, ecc.
won't build vacuum when handle released
Hi I just recently bought this pump and for whatever reason it is able to pull vacuum if i hold the handle down but when i release the handle the vacuum restores to no-vacuum - not sure what the issue is - i have disassembled and cleaned the entire unit and no signs of brake fluid or debris. Seals all look new as the unit is brand new with the exception of 1 time use which at that time it worked great - but no brake fluid has been in the gun
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
It sounds as if one of the check valves isn't working correctly or for some reason you need to prime it. If I'm not mistaken tho the pump must be hooked up inorder to work and must have at least some fluid in the reservoir to creat and maintain a vacuum.
Punteggio 1
Aggiungi la tua risposta
dustin kathy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 15
Tutti i Tempi: 586
