Salta al contenuto principale
Le lavastoviglie Whirlpool Gold Series possono essere identificate dai numeri di modello WDF750SAYM0, WDF750SAYM1, WDF750SAYM2 o WDF750SAYM3.
Dishwasher won't start
We have a whirlpool gold series dishwasher. On control panel most lights are on but faintly..to start washer I had to push start button twice for it to start..as of yesterday it won't run at all... tried unplugging it for 15 minutes and it still won't run. Any help is greatly appreciated
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
If the lights are dimmer than normal, that would indicate a power supply problem. The power supply is part of the control board. The control board is generally located in the door. It is also possible corroded pins on a connector are causing the issue.
Control boards are not cheap (~$200.) so check everything b4 you purchase one.
Punteggio 0
Hit heated dry and hi temp wash 3 times. All lights are bright. Washer runs for a minute then stops
Punteggio 0
Aggiungi la tua risposta
Ringo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 15
Tutti i Tempi: 322
