Salta al contenuto principale
The G502 was released in 2013, and its already ergonomic design was transferred to the G502 Hero in 2018. It features a 16,000 DPi sensor and a scroll wheel with a smooth, gliding scrolling feature.
10 Domande Visualizza tutte
Scroller button verso destra stops working with light touches
my "scroller button verso destra" stops working with light touches on occasions and I have to press harder and turning the scroll forward, instead the opposite button works without problems
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Sounds like the scroll wheel encoder. I actually just had a similar issue on my G603, here is the guide for that encoder replacement so you can have and idea as to what this entails.
To figure out the exact part you need you may just need to disassemble your mouse and check the part for the wheel encoder. Here is a disassembly guide for the G502 Hero. You may even find that after taking it apart and cleaning it it works again! If not just search Ebay for that part and you should be able to find it.
Immagine Logitech  G502 Hero
Guida
Smontaggio Logitech G502 Hero
Difficoltà:
Moderato
1 hour
Immagine Logitech G Series Mouse Wheel Encoder
Guida
G603 Wheel Encoder Replacement
Difficoltà:
Facile
10 - 20 minutes
Punteggio 0
Aggiungi la tua risposta
JDMys sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 38
