a/c doesn't work
clutch on a/c doesn't work. How do I fix it?
Questa è una buona domanda?
You first need to be sure why it's not working. Your ac has a low limit switch which means if the freon has leaked the clutch will not engage, if the ac relay ihas gone bad the clutch won't engage there are several other reasons. Most likely one of the two above will be the problem. If possible you need to take it to an ac repair man that you trust.
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 28
Tutti i Tempi: 418
