@christianv78099 the myth of rice as a tool for any kind of immersion accident has long been laid to rest as totally bogus. Rice does not work. It is the equivalent of doing absolutely nothing.stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using these guides iPhone XS Repair . You must remove all EMI shields from the circuit board. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Translation
@christianv78099 il mito del riso come strumento per qualsiasi tipo di incidente di immersione è stato da tempo messo a tacere come totalmente falso. Il riso non funziona. È l'equivalente di non fare assolutamente nulla.Smettete di continuare a cercare di caricare, sincronizzare o utilizzare in altro modo il vostro telefono. Questo può potenzialmente peggiorare la situazione, danneggiando ulteriormente il telefono.
La prossima cosa da fare è pulirlo. Smontare il telefono seguendo queste guide iPhone XS Repair. È necessario rimuovere tutti gli schermi EMI dal circuito stampato. Se non si rimuovono, è meglio non fare nulla. Dopo averli rimossi, pulire l'intera scheda, i connettori e tutto il resto con alcol isopropilico al 90%. Seguite [guida|5825|questa guida], e anche se è stata scritta per un Apple iPhone 3G tutti i punti sono ancora pertinenti al vostro telefono. Mentre pulite la scheda, controllate che non ci siano danni evidenti, come componenti bruciati o mancanti, ecc. Una volta pulita correttamente, sostituite la batteria. Tutti questi passaggi servono a evitare guasti ritardati causati dalla corrosione. La cosa migliore sarebbe pulire la scheda con un pulitore a ultrasuoni, ma se non si ha accesso a uno di questi, questo può almeno essere d'aiuto. Una volta fatto tutto questo, riassemblate il telefono e rivalutatelo. Finché non sarà pulito, tutto sarà solo un'ipotesi. È possibile che il display LCD sia difettoso e che la sostituzione del gruppo display possa risolvere il problema. Anche con tutto questo, i danni causati dall'acqua hanno solo poche possibilità di essere riparati completamente, ma almeno si può fare un tentativo.
Votato
Annulla
Punteggio
